TD-18a how big?
Tom
01-25-1999 12:50:08
I am interested in a 40-50s' IH TD-18a but it is quite a ways away. How big is it compared to Cat models, like a D7? Does it start and run on 12V? I know it starts on gas then switches over does it use a carb or does everything go through the injector pump? Lastly, this is a cable dozer did people convert those old guys to hydraulics? Thanks for any help.
Russell Presby
07-06-2000 22:47:21
 Re: TD-18a how big? in reply to Tom, 01-25-1999 12:50:08
i just read harolds followup and it is very acurate .but two of three td18as that i have are hydraulic and the blades were built by bucyrus erie.one of them has wedges to lock the blade in a tilted position and the other has pins with several different settings .
Joe
02-05-2001 13:36:45
 Re: Re: TD-18a how big? in reply to Russell Presby , 07-06-2000 22:47:21
Does anyone have an idea of a fair market value for a TD-18 that I would guess is more than 60 to 70 percent worn undercarriage wise with a hydraulic blade on it??
Harold H
02-04-1999 16:12:31
Tom,
The TD18A was tested in Nebraska test # 446; 97.83 belt hp, 85.61 dbr hp, 20,234 lbs pull @ 1.55 mph. CHP 101.98 belt hp, 89.29 dbr hp. It had a shipping weight of 23,630 lbs. The Caterpillar D7 of the same era was Nebraska test # 358; 89.10 belt hp, 78.48 db hp, 21,351 lbs pull @ 1.33 mph. CHP 92.84 belt hp, 80.44 dbr hp, shipping weight 25,340 lbs. The TD 18 has a 12 volt electrical system and starts on gasoline then you switch it to diesel. It had a complete gasoline system with magneto, carburator and spark plugs, and a complete diesel system with injector pump and injectors. It has a 691.1 cu in six cylinder International engine rated at 1350 rpm. If the one you are looking at does not have hydraulics, you would be much better off to stay with the cable system. It would be difficult and cost prohibitive to add hydraulics and change to a hydraulic dozer blade. There is nothing wrong with a cable system.
Harold H
