Sheppard diesel serial number
tractor Rod
07-10-2000 17:50:29
Does anyone know how I can tell what year my tractor is. Thanks Rod
Doug A
07-11-2000 14:46:44
 Re: Sheppard diesel serial number in reply to tractor Rod, 07-10-2000 17:50:29
What model sheppard(#cyls)?
Tractor Rod
07-11-2000 15:46:55
 Re: Re: Sheppard diesel serial number in reply to Doug A, 07-11-2000 14:46:44
It is a sd-3
Doug A
07-11-2000 17:28:58
 Re: Re: Re: Sheppard diesel serial number in reply to Tractor Rod, 07-11-2000 15:46:55
On left side of tractor below the radiator and above the frame rail is a slab of iron that looks like a spacer plate.you will probably have to wire brush it but there is a # stamped there.It will be 3-####.Those 4 #s will be your ser#(3 on early tractors).Advise me of that # and Ill try and help determine your year.Doug A
Tractor Rod
07-12-2000 17:43:02
 Re: Re: Re: Re: Sheppard diesel serial number in reply to Doug A, 07-11-2000 17:28:58
The number is 3 1010 hope this helps Tractor Rod
Doug A
07-12-2000 20:25:31
 Re: Re: Re: Re: Re: Sheppard diesel serial number in reply to Tractor Rod, 07-12-2000 17:43:02
Rod,your tractor is a late 1949 (first year) or an early 1950.Does it have an underhood air cleaner or is there a hole in the hood for a air snorkel.Also early Sheppards had a band type brake instead of dic brakes.Advise me of these 2 differences to narrow it dowm some more.All Sheppard ser. # ended in 5 or 0 as they wanted their competitors to think they were selling lots of tractors by issuing ser. # in increments of 5. Doug A
Tractor Rod
07-13-2000 04:16:48
 Re: Re: Re: Re: Re: Re: Sheppard diesel serial number in reply to Doug A, 07-12-2000 20:25:31
Doug this tractor has the air cleaner through the hood and has band brakes not the disc type. Thanks Tractor Rod
