EBRO DIESEL MOTOR
PAUL CLARKE
07-14-2000 13:17:14
I HAVE RECOVERED AN EBRO 4 CYLINDER DIESEL MOTOR
FROM A CASE 600 HEADER, TO SET UP AS A STATIONERY MOTOR IN AN HYDRAULIC POWER PACK.
CAN ANYONE TELL ME WHERE I CAN GET INFORMATION ON EBRO DIESEL MOTORS.
Herb krein
07-26-2000 08:30:55
 Re: EBRO DIESEL MOTOR in reply to PAUL CLARKE, 07-14-2000 13:17:14
Ebro is a spanish manufacturer I have a 470 tractor and am looking for parts and a manual
I tried to find a e-mail adress for EBRO
wich I think is in Bilbao Spain but was not able to.If someone is able to find it I would like to kno
Danny
11-07-2002 16:10:58
 Re: Re: EBRO DIESEL MOTOR in reply to Herb krein, 07-26-2000 08:30:55
I was working on a Ebro-McKee 460, and the motor is a Perkins, so I believe that is what it is.
Glorywagon
10-14-2006 13:41:38
 Re: Re: Re: EBRO DIESEL MOTOR in reply to Danny, 11-07-2002 16:10:58
Yes you will have no problem getting engine part from Massey Furgson . But the trans. and rearend are Renault. Good luck findind parts.
Brian
07-29-2000 14:21:13
Herb,
Your 470 is a Perkins 4.236 engine rated at 71 bhp at 2100 rpm, fitted to a Spanish built Fordson Super Major gearbox and rear axle.
Hope this helps.
regards
Brian
speights
10-07-2006 01:00:02
 Re: Re: Re: EBRO DIESEL MOTOR in reply to Brian, 07-29-2000 14:21:13
Hi, I have an Ebro 470 do you know if the hydraulic pump is in inside the diff or mounted to the motor. My tractor has a pump on the motor that goes to the hydraulics under the seat, is this an auxiallary pump or is it the only pump on tractor for hydraulics im haveing trouble with the hydraulics air getting in somewhere
Thanks Paul
Glorywagon
10-20-2006 19:53:48
 Re: Re: Re: EBRO DIESEL MOTOR in reply to speights, 10-07-2006 01:00:02
Hi The hyd. pump is located under the speedo in front of the gear shift. that box your talking about is the valve for the 3 point hitch.I looked for over a year and can't find one. Danny in Arkansas USA
Brian
07-16-2000 03:17:59
Paul,
Ebro is a Spanish company set up by Ford and Massey Ferguson to make tractors in Spain. The tractor was a Fordson Major or Super Major re badged and with M-F tin work. Later tractors were Super Major gear boxes/rear axles fitted with Perkins engines.
Edbro also supplied Spanish built engines as spares for Super majors.
The engine you have is possibly one of these and is a straight copy of a Super engine and all parts are interchangeable as is the workshop manual.
The Perkins engines used were badged as such and as you do not mention this I would suspect it is the Super one.
regards
Brian
Richard Thomas
01-07-2006 20:00:49
 Re: Re: EBRO DIESEL MOTOR in reply to Brian, 07-16-2000 03:17:59
curious. I am looking for an EBRO diesel to fit to a MF35 Petrol, now about 25 or so years ago an EBRO diesel was available that fitted directly to a Ford County. These were infact ford made perkins engines built at the Ford tractor factory in Spain which was nationalised by their dictator gouvernor, Tito I think it was. They just re-engraved the casting moulds to read EBRO which they did by altering the FORD letters. If you look at this you will see how they did it. The F was re-tooled to be an E, O was made into a B and so on. Cheeky buggers but the engines were identical only possibly not so well made.So does anybody know how to contact them??
Glorywagon
10-20-2006 19:57:45
 Re: Re: EBRO DIESEL MOTOR (SILLY) in reply to Richard Thomas, 01-07-2006 20:00:49
your Silly Ebro was named after the longest river in Spain.Check there history Silly.
