Carb rebuild kit.
Bill
07-31-2000 16:59:10
Have an International 3414 or B414 with an International BC144 Gas engine. Has a Zenith VN down draft carb. 3414/B414 were British made Internationals. Even the dealer can't get all the parts. I have invested hundreds custom making rebuild parts for the carb. Everything is working now but a little check valve located in the bottom of a barrel that looks like it is some sort of metal accelerator pump. The dealer can't get the check valve & gas pours out the bottom of the carb making the tractor useless. Anybody know where I might get the valve part, complete rebuild kit or a decent used carb? If all else fails I guess I can spend the $350 for a new one but I'd rather not at this point
larry
07-31-2000 17:28:10
 Re: Carb rebuild kit. in reply to Bill, 07-31-2000 16:59:10
Plug the hole and see if it runs.
Bill
08-02-2000 17:24:17
 Re: Re: Carb rebuild kit. in reply to larry, 07-31-2000 17:28:10
Larry: Sat & thought long & hard on your suggestion. Humans look but sometimes fail to see. Thinking about what you said I traced the carb circuits with carb cleaner spray. That hole could only be a factory casting access hole to drill circuits in the casting & the factory plug some how got out. Plugged the hole & everything is working great. THANKS!!!!! !!!!
