TORO TRACTOR
Dan Ginter
09-05-2000 19:01:13
Need info on Toro tractor.This is like the one in the adds with Arnold Palmer.It has a four cylinder engine.Would like to be able to tell the year. It does have a serial number plate.
troy
01-04-2001 19:52:13
 Re: TORO TRACTOR in reply to Dan Ginter, 09-05-2000 19:01:13
we have a toro tractor from the 50's. i am sure it is the same as yours or at least similar. dual rear wheels, single driver seat, some had dump boxes and a six cylinder ford motor. ours is that type. I have the origional parts manual and the mower setup. it has a cut of almost 11'. it is a very impartant part of our farm and probably works harder than it should. we are looking for a few parts for ours. in particular, the bull horn tag on the front and the toro tags on the side of what is considered the hood. Dont try to get too much info from toro. it will be a big waste of time. I was very discouraged by their assistance, or lack thereof, and they said in one conversation that they no longer had any info on them because of their age, so good luck. if you leave a reply, i will try to do the same.
gef
09-12-2000 23:11:59
Hi, You might try contacting the Toro company. They still have information on some of their old products.
Link
This link should get you started. good luck. gef
Guest
09-08-2000 05:00:03
So what does it say on the serial number plate? DUH!
Dan Ginter
09-09-2000 10:53:45
 Re: Re: TORO TRACTOR in reply to Guest, 09-08-2000 05:00:03
To Mr. DUH: Thanks for the quick and polite reply. The serial number that you requested for the TORO is 29261.
