Leyland 344n and nuffield 4/65
carl
09-15-2000 18:11:13
I made a previous about my nuffield....a neighbor has offered his leyland 344n for parts;the transmission casting number is the same,however the block casting number is very much different.the engine appears identical.Are they the same? should i persue this or dig a BIG hole for both?
Monty Pitts, Anglo-American Services Group, Inc.
12-15-2000 10:35:55
 Re: leyland 344n and nuffield 4/65 in reply to carl, 09-15-2000 18:11:13
OK gents, here are the facts: The Nuffield 4/65 has either a 38T, a 38TA, or a 38TD engine in it. The Leyland 344N has a 34TD.
Let us know if you needs parts, manuals, etc.
Monty Pitts
1-800-900-7224
Mitch in Arkansas
10-07-2000 19:55:30
Carl,
I don't know the difference between these two tractors but I just had to give my two-cents worth on the leyland 344. I LOVE MINE!! I'm in the process of finding a front-end loader for it.
It's a strong, heavy tractor that works great for our 40acre farm. Parts and books are readily available and reasonable; you may email me if you need a reference. Good luck with yours.
Larry
10-27-2000 13:01:42
 Re: Re: leyland 344n and nuffield 4/65 in reply to Mitch in Arkansas, 10-07-2000 19:55:30
I have a 4/65 myself.I bought it cheap and it is in good shape.I need help in finding parts.Can anyone help me out where I can order parts and a manual?
Jim Jelinski
11-03-2000 10:00:18
 Re: Re: Re: leyland 344n and nuffield 4/65 in reply to Larry, 10-27-2000 13:01:42
I have a Leyland-Long model 4/25 with the 1622 cc gasoline engine.
I looked long and hard, and not only could I find no source for parts or information, no-one I talked to had any ideas where to look either .
Everywhere I called was a dead end.
I searched and searched on the Internet, and was just about to give up and resign myself to having a true orphan- a great tractor, but no parts availability and no service information, when I finally came across a a lead, which turned out to be a solid source for parts and service information!
The firm is Anglo-American Services Group, Inc
P.O. Box 22877
Knoxville, TN 37933
'phone (865)-675-1505
On the Web go directly to 'http://angloamericanservices.com'.
DO NOT do a web search for this site- it will not show up (at least not as of 03 November 2000).
All the Best!
Jim
LB
09-24-2000 00:12:11
I had a nuefield 4/65 about 10-12 years ago. It was a very handy and economical tractor. Till it spun a bearing. I've heard that these and the Leyland are known for doing that. I'm not sure. If you are going to dig a hole for them, I have a hole already and would take them off your hands, :)
George From Ontario
09-16-2000 07:55:03
I have a Leyland 344 . It has been a good Tractor for the most part. The 344 was rated 55 horsepower draw bar and 45 horsepower on the PTO by the company . It replaced the Nuffield 3/45 . The 384 a 70 horse rated Tractor replaced the Nuffield 4/65 . They no doubt have many common parts, but I would think that the 4/65 would have a larger motor . I stand to be corrected !
Just my thought. George
Brian
09-17-2000 02:38:04
 Re: Re: leyland 344n and nuffield 4/65 in reply to George From Ontario, 09-16-2000 07:55:03
George,
You are right. The 384 also had improved balance over the 4/65.
regards
Brian
