What is a Long Tractor. Whats the HP of a 510 Diesel?
JB
01-31-1999 19:44:50
I found a Long 4WD, Diesel,Model 510, with loader.
I know nothing about Long tractors, and actually
thought they were some sort of Ford tractor.
Can somebody please educate me on what a Long tractor is?
Also, would like to know the HP of this 510 tractor.
Thank You, please E-mail me with your respones.
I need advice on motor problems with the EVIL LONG tractor
09-11-1999 22:59:59
 Re: What is a Long Tractor. Whats the HP of a 510 Diesel? in reply to JB, 01-31-1999 19:44:50
I have just recently purchased a 1976 LONG backhoe. For the grand sum of 7500.00 hard earned dollars. It may look like a ford but it aint no FORD.. Because I had one before this one. I have spent countless hours rebuilding this tractor.At present time the problem I'm having is the counter balance shaft that runs off of the oil pump keeps sheering the key.. Maybe someone can shed some light on this subject..Preferably someone who has had the same problem.. THANKS
Arch Bar
02-01-1999 13:13:11
Long Mfg Co, and still are (I believe) based in Tarboro, N.C. I think the tractors themselves are built in China. Company started in 1949. Modern Long tractors are cheap and rather crude tractors, along the lines of Belarus.
ken
02-01-1999 16:09:54
 Re: Re: What is a Long Tractor. Whats the HP of a 510 Diesel? in reply to Arch Bar, 02-01-1999 13:13:11
WRONG ON ALL COUNT'S!
The Long is made in Romania parts if you ever need them are very inexpensive and readly available.
they are a very simple and basic machine the HP on the 510 is 48.5 it has an ind pto and live hyd. it also has power steering.
To check the year look back where your right heel would set on the trans. housing is cast a date then add one year.if you have any Questions e-mail me
whitely pruett
01-08-2000 16:17:37
 Re: Re: Re: What is a Long Tractor. Whats the HP of a 510 Diesel? in reply to ken, 02-01-1999 16:09:54
would like to know the year of serial # 53002201 of a long tractor, and any info you can give me or a web site to go to. thanks
Arch
02-02-1999 13:47:35
Not all counts, Ken. They are from Tarboro, N.C. Thanks for the come-back on Romania, though.
Harold H
02-05-1999 16:43:52
 Re: Re: Re: Re: What is a Long Tractor. Whats the HP of a 510 Diesel? in reply to Arch, 02-02-1999 13:47:35
The Long 510 Diesel has two tests at Nebraska. The two wheel drive 510 was test # 1415; 43.27 dbhp, 49.15 pto hp. The 4 wheel drive 510DT was test # 1416; 41.37 db hp, 49.35 pto hp.
Harold H
