Pasquali help needed.
Dennis Stoeser
10-19-2000 14:18:14
I need the current e/mail address for American Pasquali.I tried the one I found on this board but it did not work. ameripasq@palacnet.net Also any useful tidbits about the 986. Is there a Web site for these little guys. Thanks.
Peter Wickenheisser
10-19-2000 16:39:16
 Re: Pasquali help needed. in reply to Dennis Stoeser, 10-19-2000 14:18:14
I think you have the address wrong. Try ameripasq@palacenet.com you forgot the e! As far as I know we are on our own as far as a real website. But if you need any help you can contact me and i will forward it if needed.I have direct contacts in Italy for really tough stuff. Jack Brunning in NH and the guy in Maine are both helpful if you need them.
Dennis Stoeser
10-21-2000 17:35:35
 Re: Re: Pasquali help needed. in reply to Peter Wickenheisser, 10-19-2000 16:39:16
The email address ameripasq@palacenet.net doesn't work either. I quess American Pasquali is off line. I need an axle for my 986.Help!
Peter W
10-25-2000 18:42:33
 Re: Re: Re: Pasquali help needed. in reply to Dennis Stoeser, 10-21-2000 17:35:35
Dennis,
Which part of which axle? Do you have it apart? If so do you have a parts manual which will give part number? I can get what you need. what is your time pressure?
Peter
Dennis Stoeser
11-01-2000 21:15:44
 Re: Re: Re: Re: Pasquali help needed. in reply to Peter W, 10-25-2000 18:42:33
I need the left rear axle that the wheel bolts onto. It broke off at the snap ring groove for the wheel bearing. I need it fairly soon. Is not apart but it looks to be easy enough to do. I have no manuals at all, but I am fairly familiar with most types of tractors. This axle appears to be like a small car conventional axle shaft.Thanks. Dennis
Peter W
11-03-2000 17:41:36
 Re: Re: Re: Re: Re: Pasquali help needed. in reply to Dennis Stoeser, 11-01-2000 21:15:44
Dennis,
It is not as simple as it looks. The other end of that axle is a gear that goes into a planetary reduction stage. It is supported by two bearings one of which is very hard to get. Have you considered having it welded? A proper machine shop can do this type of repair. Email me the serial number and confirm it is the left hand when seated and I will make some calls. give me a phone,fax, or email and I will reply.
Peter
Dennis
11-04-2000 17:55:02
 Re: Re: Re: Re: Re: Re: Pasquali help needed. in reply to Peter W, 11-03-2000 17:41:36
It is the left rear. seriel #3561. Phone 760 788 8637, email stoeser@nctimes.net. thanks
