Pasquali Back-hoe
Peter Wickenhei
10-19-2000 16:50:40
I am looking for a Pasquali 993 back-hoe attachment. Any shape, partial, or perfect. Any help or if anyone has done a conversion let me hear about it. I have all the attachment hardware and supports on my machine.
Joe Caparo
11-04-2000 11:47:29
 Re: Pasquali Back-hoe in reply to Peter Wickenheisser, 10-19-2000 16:50:40
Hi Pete, I'm not real sure what the 993 looks like, But I have A 997. It's 4 wheel drive,articulated,with A 2 cyl diesel. I have A pasq.front bucket, But I also have A bradco hoe on the tractor. If you think this may help you I could get you #'s on what I have. good luck. Joe
Peter
11-09-2000 16:25:43
 Re: Re: Pasquali Back-hoe in reply to Joe Caparo, 11-04-2000 11:47:29
Joe,
997 is same as 993 but different engine. Mine is a Ruggerini RD901/2 two cylinder air cooled. If you could get the Bradco model number it would be a big help.I have the factory loader and hoe mounts but the hoe is long gone.
Peter
Joe Caparo
11-21-2000 06:56:06
 Re: Re: Re: Pasquali Back-hoe in reply to Peter, 11-09-2000 16:25:43
Hi peter,
The backhoe Is A Bradco Model # 802A Ser # 8p151, It was On the tractor when I bought it. There is A tag on it American Trencher PO. Box 266 Deihi Iowa 52223 Phone 319-922-2981 I talked to Dave in service. I think this hoe was modified a little, but not much. I think all that was done is the seat post was cut off of the hoe, and I opperate the hoe from the seat on the tractor, Mine swivels and adjusts front to back, I don't know if this is correct. The hoe mounts with two wedge pins at the rear axel, and has a long square tube with a round pin at the front that fits into a bracket just foreward of the center of the tractor where it pivots, this bracket is aprox. 4 in. wide so the tractor can pivot, It dosent turn as well as without the hoe. I modified the front wheels, I extended each wheel out 6 in. Because I found with the hoe on and especially if I was on A hill While making even a slight turn thr front end would rise or twist, at the pivot point. there is a spool valve at the controls for the front bucket to send power to the hoe. It works fine a little slow but it's ok I put in my sewer at my house 7ft. the guy I bought it from dug graves with it. I just found more info Pasqalli mounting kit for Bradco hoe kit # 51959 Hydrolic hook up kit 997 w/loader, kit # 52285 hyd surge tank assy. kit # 52286 I hope this info is of some help. Joe Caparo
Peter
11-27-2000 17:22:09
 Re: Re: Re: Re: Pasquali Back-hoe in reply to Joe Caparo, 11-21-2000 06:56:06
Joe,
Thanks for the help I will make some calls to see where it gets me.
Peter
Joe Caparo
12-06-2000 18:52:38
 Re: Re: Re: Re: Re: Pasquali Back-hoe in reply to Peter, 11-27-2000 17:22:09
Pete,
I don't recall If I told you those kit #s were pasqualli #s from the sparce manual I have.
Also maybe you or someone else can help me , Do you know what the normal oil psi. is of A 997 2 cyl Ruggerini air cooled diesel, and the flow pattern through the filter? Is it like an automotive filter feed on the outside, return on the inside? I had an adapter made to run a GM filter, While running the machine I noticed the end of the filter bulged a little. Thanks for any info, Joe
