Universal 4500 4wd
baron
10-27-2000 20:50:53
I have a 3 cyl diesal Romanian built 4wd. I am having problems with the power steering pulsating and not responding to the turn of the steering wheel correctly. On cracking the hydrauic line on the piston I find white fluid (air bubbles?). I am guessing that the transmission fluid resevoir for the whole hydraulic system also includes the power steering. If every thing else works why won't the power steering? Can these pistons be bled ? This problem just developed after the tractor sitting for a month. Any ideas???? thanks jeff
larry wolfe
10-28-2000 16:02:35
 Re: Universal 4500 4wd in reply to baron, 10-27-2000 20:50:53
If this tractor looks something like a Massy ferguson it has a seperate steering pump and resivor. Its gear drive off of the timming gears. It needs to have fluid added.
