Wanted any info on what tractors used a IXB herc. 4 cyl.motor
Rob Swartzlande
11-11-2000 17:21:26
would like to know what tractors or power units used a Herc. IXB motor i need one and some parts for a lesser known classic i am working on Thanks Rob
John de Marrais
12-13-2000 06:37:34
 Re: wanted any info on what tractors used a IXB herc. 4 cyl.motor in reply to Rob Swartzlander , 11-11-2000 17:21:26
Avery, Cleatrac OC3, General, Silver King, ec.
JD
11-12-2000 11:03:49
I believe that the B. F. Avery model "V" used an IXB3 engine. Also some Leader tractors used Herc engines. There is a place in North Carolina that had most parts for these engines. JD
John K
11-25-2000 11:50:29
 Re: Re: wanted any info on what tractors used a IXB herc. 4 cyl.motor in reply to JD, 11-12-2000 11:03:49
What's the name of the place in North Carolina that has parts for the Hercules engines?
Thanks.
B. Changstrom
11-11-2000 21:25:49
I recently rebuilt a Hercules IXB in an Oliver crawler. Also have worked on several IXB engines in military surplus generators. I found most parts needed for a total rebuild as NOS with the exception of the main bearings which I had re-babbited.
Frank Tyson
11-28-2000 20:12:20
 Re: Re: wanted any info on what tractors used a IXB herc. 4 cyl.motor in reply to B. Changstrom, 11-11-2000 21:25:49
The early Silver Kings had IXB engines.
