Howard H2000 tractors
Russell Shaw
11-26-2000 04:41:51
Is anyone able to supply me with an almost infinite supply of information on the above. I have just acquired one (1968 model I am led to believe) complete with slasher deck, rotary hoe and grader blade, as well as various attachment bits and pieces. It has an 8 h.p. Howard single cylinder petrol engine, is belt driven to the gear box and then to the attachment from the P.T.O. It has high/low ratio, diff lock, 2 forward gears and reverse. I need info on fitting the attachments (not sure if all fittings have been included), clutch operation (it has been modified very crudely) servicing details including fluid levels, parts availablity (I live in Victoria, Australia) and a wiring diagram as it does not seem to be putting out any charge to the battery (as with the clutch, the wiring has been butchered a bit). Any other information would be most welcome. With thanks. Russell
robert moore
09-17-2005 19:31:03
 Re: Howard H2000 tractors in reply to Russell Shaw, 11-26-2000 04:41:51
I now have 30 paid up members as well as a composite list of around 100 enthusiasts detailing parts and literature availability. I have inmy possession manuals for 2000's at a cost of $10-00 plus postage($2-00) of which a donation is made to wellington high school for their assistance. Look in a magazine called The Old Machinery Magazine for Howard Register Listing. Good Luck.
John Christian
05-27-2006 18:42:25
 Re: Howard H2000 tractors in reply to robert moore, 09-17-2005 19:31:03
I am after a workshop manual for the Howard H2000 GT 16Hp tractor-Motor Model No 408,wiring spec's and any information on these tractors and imploments.
The motor runs for about 10 to 15 minuets then looses power and stops, after a short while it will restart.
The spark is yellow not blue.
Are these engines posotive or negative earth.
yours thankfully John
robert moore
07-08-2005 19:54:03
contactmeat 0268453279 or email regarding formation of Howard register. See april/may or August september issue of The Old Machinery Magazine.
Look forward to hearing from you.
Lee Arnott
06-25-2004 22:04:17
i have 1 of these tractors and have fitted and used all attachments as you have spoken about and also have a parts and service manual (i think it is the same model)i have used this tractor every day since brought at new,i need a 10 hp wisconsone engine to restore the engine though would you know where i might get a cheap 1 of these .
Lee Arnott
02-13-2005 18:20:27
 Re: Re: Howard H2000 tractors in reply to Lee Arnott, 06-25-2004 22:04:17
I too have just purchased an old Howard 2000 from the sixties.
It is missing the underneath cutting blade and Also missing a PTO belt.
Do you have, and if so how much??
At present I don't have more details as I'm at work in Sydney and the tractor is in Kempsey.
Steve Johnson
12-19-2004 08:08:28
Hi Lee,
Do you know if the Howard 2000 was produced in Australia?
thanks, Steve
