Intercontinental tractor
James
12-17-2000 14:35:23
Just saw a calender with a intercontinental tractor on it.I've never heard of such a thing,can anybody shed any light on the subject
Alberta Mike
12-17-2000 15:45:15
 Re: Intercontinental tractor in reply to James, 12-17-2000 14:35:23
I've got a tractor encyclopedia here that has a few Intercontinentals in it. They were made in Garland Texas. The model C26 is a 3000 pound tractor with a 4 cylinder Continental flathead engine of 162 cubic inches. It was made from '49-'56. It had 38" rear rubber and the grille appears to be mesh. The model DE and DF looked similar but the sheet metal was slightly different. They had Buda engines, the DE had 153 cubes (same as the Cockshutt 30) and the DF had 182 cubic inches. It had a pressed steel bar-style grille. These were made from '51-56, also from Garland, Texas. Also is a model 'Cultrac', sort of a tracked version of the tractor, only weighed 1750 pounds with a tiny Waukeshau engine of 61 cubic inches. This little tractor has the strangest track covers over the tracks that I've ever seen. It was only made in '51 and '52. Interesting, never seen one either.
TROY
02-26-2001 20:32:00
 Re: Re: Intercontinental tractor in reply to Alberta Mike, 12-17-2000 15:45:15
Looking for any books, links, or any information on Intercontinental DE & DF tractors. Where were they exported to?
Dave
12-18-2000 17:41:28
Mark Struz from Goodhue, Mn has an Intercontinental all restored, it might of been his tractor on the calendar.
larry wolfe
12-18-2000 09:37:50
They where made to be export tractors, and most where so only a few protyps and left overs are around.
