Small Leader brand tractor
Tools
12-23-2000 16:43:02
Hi folks,
Have recently seen two (different locations) small tractors similiar (at a distance) to a Massy Harris Pony, but clearly very different up close, and with "Leader" stamped in the sheet metal, appears to be a company based in Ohio. I'm guessing 10HP class, 4 cyl, live hydraulics (similiar to the Pony), 3pt hitch, not a lot of castings. It is based on frame rails similiar to a AC WC/WD/WF. Anyone know anything about these things? Are they worth restoring? Any info would be appreciated. Thanks, and Merry Christmas, Mike Danford
Guido
12-23-2000 19:02:12
 Re: small Leader brand tractor in reply to Tools, 12-23-2000 16:43:02
Leader tractors were built after WW2 in Chagrin Falls, Ohio. They used a 4 cylinder Hercules flathead motor that I would guess put out around 25 HP. I have owned two, not bad machines considering that they were essentially built off the shelf with components from outside suppliers.
JD
12-24-2000 09:28:04
 Re: Re: small Leader brand tractor in reply to Guido, 12-23-2000 19:02:12
Was there just the one model of Leader made or other sizes? What is the model designation? They seem to be pretty rare. I have one with transmission problems and I see one at a show every now and then. JD
