Satoh relation to 284 International
John K
12-29-2000 11:48:56
From what I understand Satoh manufactured the International 284. The one I have has a 4 cyl Mazda engine, 71 cu in and is 27 Hp. It was manufactured between 1976 and 1981. I was wondering if one of you Satoh owners could tell me an analogous model number for a Satoh.
Bob Saults
03-08-2003 19:28:43
 Re: Satoh relation to 284 International in reply to John K, 12-29-2000 11:48:56
anyone telling that a 284 is the same tractor as the satoh is wrong, the satoh has a 68mm cylinder and is a PB model, the 284 has a 71mm cylinder and isnt a PB engine, so beware of the information.
ROB
12-31-2000 12:27:03
an s-650g satoh is 60.2 c. in. and rated at 25 hp.
and all the replacement parts say MITSUBISHI: GENUINE PARTS.
Charlie
01-15-2001 14:14:05
 Re: Re: Satoh relation to 284 International in reply to ROB, 12-31-2000 12:27:03
The 284 is actually was built by Komatsu and to my knowlege the only way to get parts for your 284 is through your local Case IH dealer. As far as I know this was an eclusive machine for IH and nothing else cross match. Satoh's were early Mitsubishi tractors and they built the later 200 series units. They still build them and are marketed through Cub Cadet.
D.Eaton
10-03-2006 18:51:22
 Re: Re: Re: Satoh relation to 284 International in reply to Charlie, 01-15-2001 14:14:05
I have both a INt. 284 gas tractor and a satoh s-650g tractor.Both have very similiar engines made by Mazda.Some engine parts will interchange but not all.The rest of the tractor are very different.Both have different trans.,steering,brakes,body metal,frame,etx. INternation 284 is made by Komatsu while the original satoh s650g is made by Satoh itself{not to be confused with the Mitsubishi satoh 1980 and up}.Although both of these tractors in comparison are great and tough machines.Hope this is some help to someone.DD
