LONG 360 DIESEL BATTERY PROBLEMS
CHADINONTARIO
01-15-2001 00:01:04
MY 360 lONG IS GOING THRU BATTERIES. IT SEEMS TO BOIL THE BATTERIES DRY.....ANY IDEAS AS TO WHERE TO START TO LOOK TO SOLVE THIS PROBLEM? I'VE CHECKED THE VOLTAGE AND IT REGISTERS 14 VOLTS, AND I HAVE BEEN TOLD THIS IS NORMAL. THE TRACTOR IS USED IN RUGGED COUNTRY FOR LOGGING AND GETS BOUNCED AROUND CONSIDERABLY IN COLD WEATHER.
Bus Driver
01-15-2001 13:11:02
 Re: LONG 360 DIESEL BATTERY PROBLEMS in reply to CHADINONTARIO, 01-15-2001 00:01:04
If the internal connectors in the battery break loose, it will cause the condition you describe. Based on your voltage readings, I can't think of any other reason. But comparing the cost of batteries to the cost of a voltage regulator, I would replace the regulator anyway.
