LONG INFO NEEDED
chad
02-25-2001 14:42:17
I HAVE A LONG 460 WITH A (FIAT)BRASOV ROMANIA TAG ON THE MOTOR. THE ONLY NUMBER I CAN FIND IS 93000. WOULD ANY ONE HAVE ANY IDEA WHAT YEAR THIS IS? IM ALSO HAVING TROUBLE WITH THE PTO, IT WILL NOT ENGAGE UNLESS TRACTOR IS NOT RUNNING. ANY IDEAS?
marv
02-26-2001 21:19:04
 Re: LONG INFO NEEDED in reply to chad, 02-25-2001 14:42:17
On top of the cylinder head and on the right side od the differential center housing and possibly on the transmission housing you will find a four digit year molded into the casting. This will tell you when the casting was poured and will be close to the production date of the tractor.
GEO
02-25-2001 18:04:04
If your 460 does not have the hand clutch, you might check your free play at the top of your foot pedal. It should be less than an inch. If you are certain that there is not excessive free play, you can adjust your pressure plate settings through the inspection plate on the right side of bellhousing. First try to look inside and make sure nothing is broken or missing. Then adjust the three bolts in about one turn while checking the tolerance to make sure they are the same.
