Long 350 Hyd.
David Mastroser
04-16-2001 15:28:19
My Dad has a long 350 the rear lift has problems it seem the hyd. pump loses a prime or or has a air lock if I open the hyd. line fluid shoots out and I tighten the line all is fine for a while. Then the lift won't work until I bleed the line again. I also would like a service manuel and parts manuel.
GEO
04-18-2001 19:49:11
 Re: Long 350 Hyd. in reply to David Mastroserio, 04-16-2001 15:28:19
If I remember correctly, the powersteering pump and the hydraulic pump pull fluid out of the same suction tube. If the main pump is worn enough, the powersteering pump draws fluid away from it.
You might replace the hydraulic filter and check the oring on the bottom of the main pump. Make sure your fluid levels are where they are supposed to be. Maybe this will help.
However, on some models, the powersteering was equipped with it own reservoir. If yours is set up this way, check the inlet tube (suction) for dents or kinks that might obstruct flow.
