Belarus Hydraulics
Wisconsin Ron
05-02-2001 20:02:55
My uncle is stumped on his older Belarus. The remotes work real good, but the three point hitch takes 15 minutes to lower. It also takes 15 minutes to raise. That is a little slow. Does anybody have any input?
Thank you
Wiscinsin Mike
09-03-2001 15:27:33
 Re: Belarus Hydraulics in reply to Wisconsin Ron, 05-02-2001 20:02:55
I'm not too familiar with Belarus but our Leyland 384's 3 point linkage is worn out and if you don't pull the linkage from the lever to the rear it'll take a while to come up.
richard
05-08-2001 14:22:42
you dont say if your belarus has traction boost fitted,identified by 4 control levers below dashboard with a black control knob to the right of it.check that the traction boost is in the locked out position.will try to re-create problem on one of my coustomers tractors in the next week or so when foot and mouth ristritions in staffordshire are lifted
