3 point configuration
Ron C.
05-08-2001 08:41:46
I have a 3 point hitch on my Satoh 650-g. I have an original manual, but it doesn't give any info on set up as far as implements. I am using a brush hog on the back and on slight grades (running along the grade)the arms hit the tire. Too much sway. I have seen different chain set-ups but haven't had much success with the guess work. The lift arms have adjusting screws which are in all the way. Any Suggestions would be appreciated. RC
Larry
05-08-2001 09:27:05
 Re: 3 point configuration in reply to Ron C., 05-08-2001 08:41:46
You need sway bars.You can buy them for fords allmost anywhere.I would suggest you look at another tractor ,any small make that has the bars on it.You should then be able to make up a set for yourself, or get a shop to do it.
crawlerjohn
05-08-2001 19:45:28
 Re: Re: 3 point configuration in reply to Larry, 05-08-2001 09:27:05
Had simular problem with my Case-IH 245 (Mitsubishi). I took the pins off the bushhog and turned them facing in so the arms pulled more strait back.
