Toro engine
bill
05-13-2001 12:40:21
Does anybody know what types of engines were installed in toro general tractors. Can different engines be installed without major changes?
ron caudill
01-17-2002 18:30:51
 Re: toro engine in reply to bill, 05-13-2001 12:40:21
i recently have bought a used toro model 421 snowblower and was wondering if anyone could email some information on it such as engine oil what kind of oil or gear lube to use in the augers and would really like to get a copy of the manual for this machine if someone out the can email any info .....
thank you
Terry
02-16-2003 17:19:38
 Re: Re: toro engine in reply to ron caudill, 01-17-2002 18:30:51
SAE 5W 30 or SAE 10 oil. Uses any high-quality detergent oil with API SC,SD,or SE.
The auger gear box oil is 3 ounces of SAE 90 EP transmission oil.
I have an operator's manual if you have any other questions.
Bruce
05-25-2001 08:06:10
My brochure (from the 1960's) on Toro tractors states that the Toro General, ParkGeneral, Bullet, and Parkmaster models were equipped with a "Ford OHV 6 cyliner, 223 cid, Model # JF-1016, standard 6 volt electrical system." --- These were Ford "Industrial" engines. - - - - - I have other specs available if needed.
John
05-15-2001 19:20:03
Bill! What year's or year?
Are you referring to the tractors that commonly pulled Gang mower's in let's say the 70's.
If this is what you are refering to.
They had 4cyl. perkins diesels. And General Motors 250 cu.in. Gas engines. That is around the late 70's they did. They also ran dual turfs on the rear instead of tractor tires.
It actually was built more like a truck tractor.
I am thinking it even used a conventional driveline.
