Wisconsin engines ; electronic ignition conversion????
carl
05-19-2001 15:36:54
I have several things with old wiscosins;can I eliminate the points with something not as moisture sensitive?
Bradley Zeek
02-10-2004 14:51:13
 Re: wisconsin engines ; electronic ignition conve in reply to carl, 05-19-2001 15:36:54
I have a Gibson garden tractor with a wisconsin model AEH engine. The tractor and engine are over 50 years old. The magneto was a Fairbanks-Morse but the metal housing crystallized from exposure and a replacement magneto is not available anywhere or so I am told. So, an eletronic ignition conversion would be great. Any info in this regard would really be appreciated....BKZ
Kevin
06-01-2001 03:38:01
 Re: wisconsin engines ; electronic ignition conversion???? in reply to carl, 05-19-2001 15:36:54
I use to run VW engines in the swamp in Georgia.
I used hair spray on the wires and ignition...
You would be suprised at how well that will work...
Sometime our engine would be under water and keep going...
Zira
05-20-2001 16:56:26
Pertronics is probably the biggest maker of electronic ignition conversion kits for engines with dist. If that is what you are looking for, call them with the dist. number & they can tell you if they make a kit for it & which one to use. Four cylinder is usually $80-100.
