Economy tractor
Rod Podoll
05-24-2001 04:06:35
I have found a complete small tractor.It has Economy stamped into the grill.I would like to find more information on this tractor.Any help would be appreciated Rod
norma corson
09-04-2002 07:37:44
 Re: Economy tractor in reply to Rod Podoll, 05-24-2001 04:06:35
I am trying to find an economy tractor part. It's the rod that attaches to the cutter bar.(pitman Rod ?)
Roger Polidoro
06-24-2001 06:46:57
I am in need of a steering gearbox for my 1977 Economy Power King Tractor. I have found two individuals that have told me that new gearboxes were available (including the steering column) for approximately $500.00 ! I would hope that a good used one is available. If anyone has a good used steering column please contact me @ 540/ 382-7020
MIKE CHANCE
06-09-2001 05:34:15
ROD:MY FATHER HAS AN ECONOMY TRACTOR.IT'S A 1973W/A TILLER,MOWER DECK,BACK BLADE,AND A SINGLE BOTTOM PLOW. THE COMPANY NAME WAS CHANGED TO "POWER KING"IN THE LATE 70s OR EARLY 80s.THE NEWER TRACTORS LOOK MORE LIKE CONVENTIONAL LAWN/GARDEN TRACTORS.I'M NOT SURE IF THEY ARE STILL IN BUSINESS.I USED TO SEE ADDS IN THE BACK OF MAGAZINES LIKE "MECHANICS ILLUSTRATED" AND "POPULAR MECHANICS". IN ALMOST 30 YEARS THE ONLY PROBLEMS MY FATHER HAS HAD IS ONE STARTER AND TWO BATTERYS.
GOOD LUCK MIKE
JOHN
06-11-2001 14:51:10
 Re: Re: Economy tractor in reply to MIKE CHANCE, 06-09-2001 05:34:15
NEED TO GET MY TRACTOR ENGINE RUNNING LIVE IN THE CHICAGO AREA DOES ANYONE KNOW A REPAIR SHOP FOR IT. GREAT MACHINE IT IS A MID 70'S MODEL I KNOW THE PROBLEM IS ELECTRICAL. OR POSSIBLE STARTER. DO YOU KNOW OF A PLACE FOR PARTS AND i COULD FIX IT MYSELF THANKS JOHN
Fred Hyman
06-23-2001 15:40:40
 Re: Re: Re: Economy tractor in reply to JOHN, 06-11-2001 14:51:10
Hey John,
I have a 1968 Power King that is still running well and I just finished mowing my lawns and small field today.
I have had electrical problems over these many years, but they have all been easily fixed. I suggest you look in this order:
1. the key switch (if you haven't already changed it.)
2. the wires, all.
3. The plug which I am sure you have changed, but also the wires. This is a a breakdown spot.
4. The condenser which I have replaced 4 times over the years.
5. The coil.
If all these are working it probably not electrical.
Let me know.
M.B. Tomlinson
06-03-2001 09:37:01
I too, am having difficulty in locating info about my tractor. If you will Click on "tractor barn" they will have some good Info re:Economy tractors. Keep in touch, maybe we can locate info together.
MIKE CHANCE
06-09-2001 05:18:15
 Re: Re: Economy tractor in reply to M.B. Tomlinson, 06-03-2001 09:37:01
MY FATHER HAS A ECONOMY TRACTOR.IT IS A 1973 W/A TILLER,MOWER DECK,BACK BLADE,AND A SINGLE BOTTOM PLOW. THE COMPANY NAME WAS CHANGED TO POWER KING IN THE LATE 70s OR EARLY 80s.THE NEWEST ONES LOOK MORE LIKE A CONVENTIONAL LAWN/GARDEN TRACTOR. I'M NOT SURE IF THEY ARE STILL IN BUSINESS.I USED TO SEE ADDS IN THE BACK OF "POPULAR MECANICS","MECANICS ILLUSTRATED" AND MAGAZINES LIKE THOOSE. IN ALMOST 30 YEARS THE ONLY THING MY FATHER HAS HAD TO DO IS TO REPLACE THE STARTER AND THE BATTERY.
GOOD LUCK MIKE
M B Tomlinson
06-15-2001 17:44:32
 Re: Re: Re: Economy tractor in reply to MIKE CHANCE, 06-09-2001 05:18:15
Thanks for the follow up Mike, will get back to U if any more Questions, OK!!
tomatolord
05-24-2001 12:25:52
Here is the link
and
Yahoo has a realy good club as well.
Rod
05-24-2001 17:13:45
 Re: Re: Economy tractor in reply to tomatolord, 05-24-2001 12:25:52
Thanks for the help on the economy tractors.I still need to know the serial numumbers and front tire size. Thanks Rod
larry
05-24-2001 09:37:34
There is an Economy site but don't know the address,do a search you might find it.
