Continental tractor?
Dug G.
05-26-2001 17:15:50
Recently ran across a tractor at a dealership that had ccontinental stamped into the front grill, and red seal (I'm guessing its a red seal engine) on the side of the hoods. It had a muncy transmission, offset seat to the right if facing from the front, and the ind. brakes and clutch on the right side of the transmission. It also had a frame around it (looked like maybe for cultivators?). Anyone have any info on this tractor? I'm hoping to swing back in monday and try to get some more info of of it. Thanks.
Dug G.
Richard
05-31-2001 17:27:23
 Re: Continental tractor? in reply to Dug G., 05-26-2001 17:15:50
The tractor is probably a Worthington, which were made for pulling gang mowers around golf course and large estates. The power unit is a Continental, but you'll more thatn likely find a Worthington ID plate on it if you look.
jaw
05-26-2001 19:03:03
There was a continental tractor company in ohio in the late teens early twentys but your tractor sounds a lot newer I am looking forword to hearing what it is. Good luck...
