Long tractor-PTO
angela
06-03-2001 12:09:32
Need info on the pto for a long tractor model number #445 . PTO will not engage any help please. Thank You , Angela
Ashley Grimes
08-23-2001 18:38:47
 Re: Long tractor-PTO in reply to angela, 06-03-2001 12:09:32
i need parts for a 445 long. please let me know if you know i could posibly get them.
marv
06-03-2001 21:09:11
Need more info on the problem. How does the clutch behave? How does the pto shift lever behave? Do the gears clash when shifting? Will it go into gear?
Angela
06-04-2001 16:33:34
 Re: Re: Long tractor-PTO in reply to marv, 06-03-2001 21:09:11
clutch is ok , no noise when shifting , and goes into gear good . PTO goes into gear but will not lift , also I need a book on this tractor one that goes into more detail . the one i have is not to good . Thank you so much, Angela
Jason
06-07-2001 16:58:48
 Re: Re: Re: Long tractor-PTO in reply to Angela, 06-04-2001 16:33:34
What do you mean by the pto goes in gear but it won't lift? what won't lift?
Brian
06-13-2001 21:36:05
 Re: Re: Re: Re: Long tractor-PTO in reply to Jason, 06-07-2001 16:58:48
The check-value (located under seat) is stuck, remove and clean piston, lube and replace. 20 min. job just done my 2 mo ago
sam
06-14-2001 08:20:37
 Re: Re: Re: Re: Re: Long tractor-PTO in reply to Brian, 06-13-2001 21:36:05
Thanks Brian. My lift (not pto) was not working either. I changed old fluid, cleaned the filter, and cleaned the valve. Works fine now.
