Long power steering
Ray Don
06-12-2001 15:54:01
My dad has a early 70's 360 long tractor with power steering problems. He had the first pump rebuilt and after reinstallation it would work only in one direction. He purchased a new pump and it made no difference. By the way the only reason he had the first one rebuilt was because it was leaking. Anyone had simular problems?
curley
01-30-2005 11:29:34
 Re: long power steering in reply to Ray Don, 06-12-2001 15:54:01
Could you tell me what power steering fluid is used for a late 1970's Long 610?
Thanks,
Curley
marv
06-12-2001 21:25:46
Sounds like the problem is with the cylinder, not the pump. Depending on the type of cylinder, maybe it can be adjusted. Describe your cylinder. Is the ram (shiny part) at the front or rear? What diameter is the ram?
Ray Don
06-14-2001 14:20:30
 Re: Re: long power steering in reply to marv, 06-12-2001 21:25:46
The ram is on the front and is 1 & 1/4 inches in diameter. It is adjustable but no matter how it is adjusted the problem just reverses to the opposite direction. It acts like some valve in the cylinder will not reverse and allow the power steering to operate in the opposite direction. Any ideas ?
