Deutz 8006/10006/13006 torque spec's
Terry Morin
06-24-2001 12:41:03
Does anybody out there have any information regarding torque values for these tractor models? I need the cylinder head, mains and connecting rod values. Thank you
Bernh. Voßen
08-13-2001 15:30:54
 Re: Deutz 8006/10006/13006 torque spec's in reply to Terry Morin, 06-24-2001 12:41:03
the corrct definition of the engine is F6L912, but 8006,10006 and 13006 got the same engine, only other injector-pumps, and I believe the 13006 got a turbo-loader
HTR
06-26-2001 14:23:51
All these bolts are tightened by the torque turn method. The head bolts are torqued in five steps. start with initial torque of 40 nm (newton meter) about 30 ft.lb. from corner to corner, second step is turn bolts 45 degrees corner to corner, third step 45 degrees, forth step 45 degrees, fifth step 30 degrees. This is a total of 165 degrees from the initial 30 ft.lb.
Main bearings, 30 nm about 22 ft.lb. second step 60 degrees, third step 45 degrees, total of 105 degrees after the 22 ft.lb.
They recommend new rod bolts, first step 22 ft.lb. second step 60 degrees, third step 30 degrees for a total of 90 degrees after the 22 ft. lb.
I think all of these tractors use BFL/912 engines and all have the some torque values.
