Graham-Bradley tractors
B. Mulcaster
07-15-2001 11:50:07
For a Graham-Bradley tractor with a 6 cylinder continental engine, 226 cubic inch, I need to know the tappet setting.
NANCY KRAUSE
08-08-2001 21:19:39
 Re: Graham-Bradley tractors in reply to B. Mulcaster, 07-15-2001 11:50:07
I AM INTERESTED IN BUYING A GRAHAM BRADLEY FARM TRACTOR RESTORED. I WANT IT AS A SURPRISE GIFT FOR MY HUSBAND
AL
07-16-2001 17:06:52
The 1949 Thompson Repair and Tume-up Manual says to set Intake and Exhaust at.010" (hot). Remember, this was in 1949 and the valves may have been changed since then!
john
07-15-2001 12:41:50
Your engine model should be F-6226 Bore and stroke is 3 5/8 x 4 3/8 compression ratio 6.70 to one firing order 153624 plug gap .025 points gap .020 tappet setting is .014 hot intake and exhaust are the same. John..
Les
07-16-2001 19:58:17
 Re: Re: Graham-Bradley tractors in reply to john, 07-15-2001 12:41:50
My books say .014 hot for the valves but the bore says 3 5/16.
George Miller
08-16-2001 04:51:01
 Re: Re: Re: Graham-Bradley tractors in reply to Les, 07-16-2001 19:58:17
John My orginal Graham-Bradey Tractor Shop Manual, form the Graham- Page Motors Crop said;
Running and hot set at .010. Final ajustment Two feelers should be used .008 and .010. The .008 feeler should pass though freely while the .010 feeler should be fairly tight. Points are .018.
George
