Carbeurator for Continental Red Seal
Rodney
07-15-2001 13:57:47
I have to rebuild a carbeurator on my Continental Red Seal engine. I believe it's an updraft type. I am not familiar with this older machine. The carb has Zenith, made in USA embossed on it. Where is the best place to get a rebuild kit? Any hints on settings? Also need a water pump or rebuild kit. Your help appreciated. Thank you. Rodney
Rodney
07-18-2001 12:01:53
 Re: Carbeurator for Continental Red Seal in reply to Rodney, 07-15-2001 13:57:47
Thanks For everyones help. With the info I was sent I have the carb rebuilt and have ordered the correct insert for the water pump. I should be able to reassemble next monday as long as the parts come in as scheduled. It runs as I fired it up after installing the Carb but now I have the water pump off I am going to replace the wiring. Thanks Again.
Gary
10-13-2003 09:51:17
 Re: Re: Carbeurator for Continental Red Seal in reply to Rodney, 07-18-2001 12:01:53
Rodney you can find a lot of parts for the Continental Red Seal engine such as carburators, water pumps and radiators at www.weldmart.com just click on picture of the Lincoln SA-200 welder.
John
07-15-2001 16:28:26
What is the model #s on the engine and any #s on the carb? It should be no problem finding the parts with the right info..As a rule of thumb I always turn scews all the way in by hand then one and a half turns out then start and adjust from there..
