Silver King What is it?
Alvin-Va
07-20-2001 20:04:32
Need some help in identifying a Silver King I am looking at,totally in the dark on these tractors.Wide front,cast spoke wheels,Hercules engine,Ser# seems to be 1748.Checked the ser.# section on this site ,no help.On the Silver King site I found what I think is the tractor but the caption reads'castspokemower',no refrence to tractor ID.Would appreciate any help in identifying.Tractor seems complete,good shape,supposed to run OK,have not heard run or talked to owner.With this info, would anyone place a price range on this tractor,would like to know before I talk to owner.Located in central Va.Any help would be greatly appreciated.
Larry
07-21-2001 16:47:48
 Re: Silver King What is it? in reply to Alvin-Va, 07-20-2001 20:04:32
I would say 1500 to 2500.The older tractors and the spokers are more desirable than the newer ones. If your ser n. is correct it is a 1936. The third year of production,985 made that year.If on rubber has R and two numbers as a model number.My guess would be a R44. A very desirable tractor both old,unusal and small easy to transport. You may have to double the above numbers to get it.
Alvin-Va
07-23-2001 08:06:00
 Re: Re: Silver King What is it? in reply to Larry, 07-21-2001 16:47:48
Larry,thanks for the response,doesen't seem like any bargains today.Called the dealer that has it on his lot,says lady will not come below $3500.He says water ran out of trans. case when they unloaded it.If anyone is interested I will get contact info.Thanks for your help.
Alvin
