Avery V, again
carl
08-27-2001 15:22:43
My newly purchased Avery has serial # v756;what year is it and could this explain the presence of the spindle mounted wheels? What other Avery had these direct mount rims? Can anyone suggest a good source of parts? I really can't afford a parts tractor. THANKS
jim forsyth
09-11-2001 10:38:59
 Re: Avery V, again in reply to carl, 08-27-2001 15:22:43
I have some used engine parts, what are you looking for?
Keith Ault
09-17-2001 08:50:29
 Re: Re: Avery V, again in reply to jim forsyth, 09-11-2001 10:38:59
Try CORK LEMMON in Camden ,Michigan.Ole Cork has lots of parts and really a good guy,except for his cheating a little at our Avery Tractor Pulls(just kidding)
Rick
08-27-2001 17:00:39
The number just in front of the V in the serial number will tell you the year of your tractor. 1VXXX is a 1947. Look at the serial numbers for the V on this web site.
Ollie
08-28-2001 06:21:18
 Re: Re: Avery V, again in reply to Rick , 08-27-2001 17:00:39
Rick is correct, just go over to the left under RESEARCH & INFO and below that SERIAL NUMBERS.
Chuck
09-10-2001 17:32:46
 Re: Re: Re: Avery V, again in reply to Ollie, 08-28-2001 06:21:18
My V serial # 1V-743 is a 47. It has the spindle mount fronts on an adjustable front axle. I have started restoring mine and have found most of the parts to rebuild the engine but I too am strugling to find either a resonably priced parts machine or a good source of salvage parts. I am also finding that the farther south you are the more common these little machines seem to be. My bad luck since I'm in southwest lower Michigan. If you find a source for resonably priced parts let me know!
