Schramm Air Compressor
James D. Compto
10-05-2001 05:09:01
I have a Schramm Model 35 air compressor, Ser # 40404. It appears to have been manufactured from a Wisconsin V-4, using 1 bank as the compressor and the other as the engine. I can't find any information on this compressor, so don't know when it was built, if parts are still available, etc. I'd appreciate any information on this unit. I plan on using it, however, I suspect it has some collector interest, so I don't want to abuse it.
mark bulissa
05-13-2006 08:14:37
 Re: Schramm Air Compressor in reply to James D. Compton, 10-05-2001 05:09:01
I have a shramm 6 cylinder eng with tha air compressor that is mounted on 4 wheels that says uss marines quamm on the side of it,and it's a very ugly shade of green. It could be for sale.
Jeff Temple
05-25-2004 08:00:42
You can get most of the parts through NAPA or look in your phone book for anyone that supplies parts for air compressors. I also own a model 35 and did a major over haul about 5 years ago, we got all the parts we needed for it through a auto parts dealer by the name of Rodefelds Auto Parts.
You can also check with Wisconsin engines
John McCarty
08-06-2005 14:05:28
 Re: Re: Schramm Air Compressor in reply to Jeff Temple, 05-25-2004 08:00:42
I have a schramm air compressor model 35 that i am trying to get information on and possibly some books or copys in regards to the compressor part and operation . I also need anything on what kind of wisconson motor this is and the original color it was painted I want to use this compressor but also want to take it to some shows.the sn. is 39895 and o\e sn is mpw vd-sk the tank appears to have been made in 1962 can anyone help me thank you john
johnny moore jr
12-04-2002 02:28:13
I ALSO OWN A MODEL 35. PLEASE FORWARD ANY INFO YOU COME ACROSS TO ALIRMETH@YAHOO.COM
Larry Evans
10-16-2001 19:35:18
Try a chap by the name of Frank McBride at the Lena Warehouse in Dallas, Texas. He has a number of parts for the old units. Fax number is 817-370-0316.
Frank Totten
10-10-2001 09:53:41
Please send me any information you might have
concerning a schramm 125 air compressor tractor.
Needing intake manifold and valve cover gaskets.
Larry Evans
10-16-2001 19:43:31
 Re: Re: Schramm Air Compressor in reply to Frank Totten, 10-10-2001 09:53:41
On the 125 Schramm tractor- Lindsay Used Tractor Parts Ltd. have one of these units in their yard. Not known if a manifold is on it or not. E-mail is: tractors@nexicom.net Fax number is 705-324-5358. They are located 5 miles south of Lindsay on Hwy 35, Ontario, Canada.
Damon
01-07-2002 13:15:07
 Re: Re: Re: Schramm Air Compressor in reply to Larry Evans, 10-16-2001 19:43:31
Looking for a magneto to fit a l25 schramm tractor
3for air and 3 for engine.It is a 1959 model. If you have or know someone who does contact me. Thanks
tony haskell
12-01-2001 17:56:13
We are looking for a 6 cylinder head to convert from air compressor to straight engine. The tractor is a 1960 125 shramm with an international rear section.
Bill
10-06-2001 09:14:54
I had a Schramm "Pnuematractor" a short while ago. Tractor/Loader/ Back-hoe with a 6 cylinder engine made by Schramm hooked to a Farmall transmission/rearend. 6 cylinders, the conventional in front, 3 to the rear of the inline 6 for air power to a jack hammer or whatever. When you engaged the compressor/called for air, you pushed a rod that let the lifters collapse on the rear 3 cylinders & she pumped air. Once satisfied either by pressure or you pulled the rod, the lifters would pump up & the valves would stay open & the 3 rear cylinders just coasted. Was a middle 50's unit. Found Schramm through a Yahoo Yellow page phone search. They were still in bussiness but no web page. Had pricy parts available. A main bearing set for the engine for example was $1000..... I lost my interest in her after that.....
