Satoh 650G
Beachnut78
10-26-2001 09:40:28
I just bought a satoh 650G and we are having a hard time getting enough oil pressure out of it. The manual specifies 53psi constant pressure. We have check the oil pump and crank and they both meet factory tolerances. Is this a common problem?
donnie
11-11-2001 03:54:49
 Re: Satoh 650G in reply to Beachnut78, 10-26-2001 09:40:28
i recently bought a 650G at auction. everything works well with it but i would like to find out more about the satoh, manuals and parts? any ideas?
Bill
11-03-2001 19:22:06
We have just bought a Satoh 650g. Would like to know where to get a manual and parts.
ROB
10-28-2001 03:46:14
yours has an oil pressure cage? mine has a dummy light.but check the satoh board at
www.antiquetractorsonline.com
lots of got stuff there...
Beechnut 78
10-30-2001 05:12:42
 Re: Re: Satoh 650G in reply to ROB, 10-28-2001 03:46:14
The tractor has a dummy light, but when the engine idles down to about 500 rpms the light comes on. So we took out the dummy light sending unit and put a gauge in the hole. Thanks for the information!!
ROB
11-03-2001 15:56:54
 Re: Re: Re: Satoh 650G in reply to Beechnut 78, 10-30-2001 05:12:42
THE BOOK SAYS IDLE SHOULD BE AT OR JUST ABOVE 700 RPM. COULD THIS BE YOUR PROBLEM ?
Beachnut78
11-07-2001 12:20:18
 Re: Re: Re: Re: Satoh 650G in reply to ROB, 11-03-2001 15:56:54
We found the problem. At the front of the engine there is a small pipe that sticks out near the timing chain that lubricates the chain. Evidently the tensioner was not working and the chain caught the pipe and tore it out of the block, causing oil to flow very fast, not building up any pressure. We made a new pipe and it holds great oil pressure now. Thanks for the information.
