Manifold for Chrysler engine in Custom
Irv Plitzuweit
11-29-2001 10:27:11
I am looking for information on how I might get an exhaust manifold for my Custom tractor. I has a 6 cylinder Chrysler Industrial engine. On the serial plate it reads IND-5A-210 41402. Might this be the same engine that Massey Harris 101 used. I thought theirs were 201 cubic inch or 217.
Does the 210 on the plate mean it is a 210 Cubic inch? Any informaton appreciated.
Bus Driver
12-09-2001 18:54:21
 Re: Manifold for Chrysler engine in Custom in reply to Irv Plitzuweit, 11-29-2001 10:27:11
Maybe the information I am posting is not really a response to your exact question, but the manifolds from Dodge or Plymouth 6 cylinder engines up through the 1959 model year will fit. By 1959 displacement was 230 cubic inches, but the gaskets sets interchange as do the manifolds. In addition, these basic engines were used in lots of equipment. Had a 1951 Yale forklift with one of them on propane. Welding outlet in another location is not difficult. Use arc welder and non-machineable cast iron rod. Weld deposit can be ground smooth. Once I put 3 carbs and dual exhaust on 1955 Dodge pickup this way.
Irv Plizuweit
12-10-2001 06:34:05
 Re: Re: Manifold for Chrysler engine in Custom in reply to Bus Driver, 12-09-2001 18:54:21
Got a manifold from a 55 plymouth flat head six. Exhuaust in in a different position, but with a little work it should fix. Working on it today. Will let you know how it all works out. Thanks for all the help. IRV
Stan Keys
12-09-2001 07:21:37
Irv
The 5A engine is a 217.7 cu in engine. The manifold you need, needs to be for a down draft carb. The Masseys used an up draft carb. Also the exhaust came out the top side at the front on almost all of them.
Don L.
11-30-2001 06:59:40
I a have this manifold, for the small block Crysler $245.oo Don L.
ph 507 433 0073 am best
L Hud
11-29-2001 15:16:30
The 5A engine is a 217. It should have a bore of 3 1/4 and a stroke of 4 3/8. The 6A was the 230 and the 8A was the 251. Manifolds are hard to find. I made one out of a Dodge truck manifold. That's all the company did. I made a split mainfold for mine. The truck manifolds were made a lot later and are in better shape. Good luck.
larry
11-29-2001 15:02:58
My 1946 book shows a ind-5(112) that has 217ci.The ind-5A might be a later version.Apparently the number after the first one is not the ci, none of the other crysler engines match either.
Irv Plitzuweit
11-29-2001 19:30:46
 Re: Re: Manifold for Chrysler engine in Custom in reply to larry, 11-29-2001 15:02:58
Thanks to all of you for the info I requested. I have printed it our and will follow up on it.
Irv
fordson29
11-29-2001 14:57:42
Irv,The MH 101 also used a Chrysler of 201 cubic inch where the 101 Super used a 217 cubic inch engine. I would geuss that the manifolds were the same on either one. They are more common then the customs so you may have better luck hunting for one for a Massey Harris. Jonathan (JJK Tractor Salvage)
Don L.
11-30-2001 07:04:01
 Re: Re: Manifold for Chrysler engine in Custom in reply to fordson29, 11-29-2001 14:57:42
I believe the custom manifold exited out the side of the manifold , and the MH Super exited out the rad. end and up. But it will bolt up!!! Don L.
