Rust treatment
bill b va
10-09-2001 20:53:21
how should rusty metal be treated to prevent continued rusting under the new paint ? in heavily rusted items it is not always advisable to grind or sand out all traces of rust . this is especially true in sheet metal . is there a chemical treatment ?..... ...thanks bill b va
Mike Schotte
10-10-2001 15:22:44
 Re: rust treatment in reply to bill b va, 10-09-2001 20:53:21
I bought 5-gallons of the Evapo-Rust product. I liked the fact that it was non-toxic, and could be disposed of down the sink when the solution is spent.
So far, I've de-rusted a grille, radiator shroud, unfrozen the handle of my tractor crank, and taken the rust off of numerous rusty bolts. I'm happy with it, but you have to be patient while it works.
I only wish I could find a Rubbermaid tub big enough to dip the ENTIRE TRACTOR!
I've got before & after photos of my parts scanned if you want to see how it works.
Mike Schotte
1949 Case SC
olen
10-18-2001 19:52:44
 Re: Re: rust treatment in reply to Mike Schotte, 10-10-2001 15:22:44
mike evapo-rust will take blueing off of guns also without the harshness of acid,pocket knife,i've derusted most everything on my 49 farmall c and still looking for other things,i also tried it out on some of my rusted fish baits and doesn't affect the paint on them but sure got the hooks clean and ready to catch another of those big mouths,good luck,olen
Mike Schotte
10-18-2001 20:42:06
 Re: Re: Re: rust treatment in reply to olen, 10-18-2001 19:52:44
Hi Olen,
I believe it was your son-in-law that called me at my office when I purchased the Evapo-Rust product. I was having trouble with the Dallas distributor, and he got me taken care of in a hurry. When I mentioned where I'd heard of the product, he said it was probably you who posted the note.
Regards, -Mike
Rod MI
10-10-2001 23:18:08
Mike how much dues it cost and how dues it compare to acid or hot tanking this I think this is what I bean looking for thanks Rod MI
Mike Schotte
10-11-2001 03:30:52
 Re: Re: Re: rust treatment in reply to Rod MI, 10-10-2001 23:18:08
I haven't tried acid. I did use hot tanking on my gas tank, but I would definitely try Evapo-Rust on my next tank. (The results are similar, except hot tanking might remove more paint.)
The product costs around 13.00 a gallon, and I got my 5-gallon jug for about 80.00 with shipping. Seems high, but supposedly each gallon will do 300 lbs. of rusty metal before the solution is spent.
I added up what I had to de-rust and how much elbow grease it would take... and decided that it was worth the cost.
Sorry I don't have a web site or I would post the "before" and "after" photos of the parts I've done with the product.
Good luck!
-Mike
Rod MI
10-11-2001 08:04:32
 Re: Re: Re: Re: rust treatment in reply to Mike Schotte, 10-11-2001 03:30:52
The photos are note kneaded Evapo-Rust has sum on there web sight but I just wonted to check with there customers and it looks like I will be trying it out farley soon thanks Rod MI
Calvin
10-12-2001 21:55:46
 Re: Re: Re: Re: Re: rust treatment in reply to Rod MI, 10-11-2001 08:04:32
Hello I have a snow blade for a Cub Cadet my uncle gave it to me but he sandblasted it and now its rusted. I hate to start sanding on all those curves and stuff where do you buy this rust remover your talking about? Thanks a lot.
Clooney
10-10-2001 03:20:48
Bill, after blasting or rotary wire brushing I usually use a "rust killer" that consists of Phosphoric Acid. Almost all the metal conditioners & rust killers contain a fair amount of phosphoric acid. The stuff I use is from a place in California called "THE SHOP". I don't have their number handy but if you E-Mail me later I will look it up & send it to you.
olen
10-10-2001 14:35:17
 Re: Re: rust treatment in reply to Clooney, 10-10-2001 03:20:48
check out the web site www.evapo-rust.com,you'll find the best rust remover on the market and it doesn't have any of the acids. i've had very best results with this,including gas tanks,rusted sleeves,carbs ect,check it out. good luck
Bill
10-13-2001 07:29:52
 Re: Re: Re: rust treatment in reply to olen, 10-10-2001 14:35:17
I have tried just about every kind of thing you can imagine to do away with rust. Muratic, Phosphuric and Hydrochloric Acid. They will all kill rust but have to be made neutral with Baking Soda and cold water after. To do it the cheap way I bought a toilet bowl cleaner "The Works" from the Dollar Store. Just a little bit will let you wipe surface rust off bare sheet metal and it also has a rust inhibitor in it. I tried it on some new metal and left it outside . It didn't flash rust again for several days. Acid is dangerous to work with . Work Safe !
Curt K.
10-27-2001 18:32:13
 Re: Re: Re: Re: rust treatment in reply to Bill, 10-13-2001 07:29:52
"The Works" is a hydrochloric acid solution with a rust inhibitor. be careful with it.
