Painting Aluminum
KB
03-13-2002 18:37:34
What is the best way to prep and paint Al so that the paint sticks and doesn't peal off.
Rod (NH)
03-14-2002 20:21:33
 Re: Painting Aluminum in reply to KB, 03-13-2002 18:37:34
Hi KB,
You might want to read the posts in the thread below for some things to consider regarding preparing aluminum surfaces for painting.
Rod
Don
03-14-2002 17:27:42
Clean the Aluminum surface good, remove any previous paint wipe it down good with thinner/reducer and prime it with 2 part epoxy primer.Then paint it with the desired finish paint. Wear a good filter mask when spraying epoxy primers, do it in a well ventilated area (I paint outside in open air).
