WD-40
Pete/ME
12-26-2005 02:48:43
Try as I might, I just can't get the barn warmer than 45 for longer than a half hour, and that's with the salamander and the barrel stove going. Warm enought to work, but no chance with paint. Plenty of sanding and wirewheeling to do though. To keep things from rusting up until May, I was thinking about spray caning a light coat of WD, and then rinsing everthing off with paint thinner or wax and grease cleaner when I go to paint. Is there something better that will work in the cold?
B-maniac
01-07-2006 19:03:39
 Re: WD-40 in reply to Pete/ME, 12-26-2005 02:48:43
WD 40 should never be used in the same room as paint will be used. It has silicone in it and it will circulate with the air in your shop and end up every where and will contaminate your new paint job with little craters called "fish eyes" ,will look awfull and take a lot of work to correct.
rockie
01-03-2006 19:48:43
I am in the same situation. Got the body parts in a shed that can be kept above 60. Frame and engine were sitting outside and I felt I could not prime and paint until the weather warmed. I coving the project tightly with plastic sheeeting and placed small electic heat under engine area. Surprised to find tractor and area under the plastic was in mid 60's within a day. I uncover and grind off old paint for a few hours each afternoon then recover and heat the rest of the time. I have not seen rust in the four days since starting this practice. I will skip out of work early tomorrow to put on the primer coat and plan to keep her covered for a week or so. Winters are mild here in SC 34-50 F, but reducing the area you try to heat may be the trick. Humidity is high here so battling rust is a concern for me. Good luck with your project.
Rockie
CNKS
12-27-2005 18:06:24
The link Rod gave pretty much explains Picklex. I will add four qualifications, though. 1. Be careful with it on cast, as cast is pourous and will absorb it. I usually scrub cast before painting, and use repeated applications of wax and grease remover until the rags come back mostly clean (all the way clean is darn near impossible) That said, thus far I have had no problems with it on cast.
2. It says you do not need primer -- I don't believe that -- I use it only on clean metal that has had the rust mechanically removed. I do not use it as a conversion coating (i.e. on rusty metal) except for rust in the nooks and crannies that I can't get to. Otherwise it is used only as a protectant.
3. The spec sheet says to ignore the white coating. I don't, I remove as much as I can. I don't consider the coating to be completely bonded to the metal and I am afraid it will interfere with adhesion of the paint. I can't prove that, I simply prefer to scuff it and remove what I can with wax and grease remover.
4. The info says do not use it in combination with etch primer (I don't use etch anyway). I doubt if you will even consider it, but don't even think about using etch primer AND Picklex on cast.
Rod (NH)
12-27-2005 17:41:38
Hi Pete,
I wouldn't use WD40. I dislike using something that I know I will have to completely remove at some later time. Picklex20 is a good product for doing exactly what you want without additional work later. I have used it in a situation like yours. CNKS also uses a similar product containing phosphoric acid that is available at Home Depot (I think) but I haven't tried it. Do a search on the word picklex in this forum and you will find one or more posts where he describes that alternative. A tech sheet on the Picklex is available here if you are interested.
third party image Rod
