Tractor Paint
Joel H.
01-08-2006 12:29:03
I want to paint a U MM for antique tractor pulling. I am not looking for a show quality finish. I do not want to take the cast iron parts ie. rear end , tranny, and engine down to bare metal if I don't have to. I am using Agco Prairie Gold paint. Can I just paint over the old paint? or should I put primer down first? Will this work? Old paint , I believe , is original and mostly there. Thanks
RedJD
01-09-2006 13:07:07
 Re: Tractor Paint in reply to Joel H., 01-08-2006 12:29:03
I have painted several without stripping the paint off the cast parts and it works very well. Make sure you have the cast clean and remove all the rust.You should use a rust covertor on any parts you can't get the rust off.
But as far as the sheet metal goes its worth the time and money to strip it down to the bare metal and use a good primer.
