John Deere paint
harvo520
01-08-2006 13:08:16
I would like to use the Cross Fire paints from Napa. Does anyone out there have the codes for the Cross Fire paints of green and yellow? Has anyone used these paints? Thankyou Harv.
Mike (SC)
01-10-2006 15:06:19
 Re: John Deere paint in reply to harvo520, 01-08-2006 13:08:16
I use the crossfire paint all the time. I use the acrylic urethene or acrylic enamel depending on what I am painting and have had good luck. Since you didn"t mention what you are painting here are the both of the green sales numbers, Industrial Green 11146 and regular green 3737 For the yellow there are 2 industrials one is 42586 and the other is 4709 the number for the regular yellow is 3739. Just give them those numbers and they can mix it for you. They should also have an equipment and tractor color chart you can look at. Mike
CNKS
01-08-2006 16:48:14
I believe Cross Fire is the same as Martin Senour, ask on the JD forum, someone should know.
