Just to be technically correct, the real problem is not that good fresh charcoal filter respirators can't remove Isos; they can and they do under controlled circumstances.... but you are playing Russian roulette with your health... the real problems are threefold: 1- Iso's are very toxic and small amounts, even single exposures can sensitize you (make you more susceptable in the future) or even cause acute respiratory problems. So, even a small exposure is an issue. 2- Iso's can break through charcoal filters without you knowing it. They have very little odor. There are no indicators when you have saturated the filter. 3- Charcoal filter masks are negative pressure (when you inhale) devices. How well they seal is an important issue. Even small leaks can let the dreaded iso's in. Supplied air positive pressure devices don't have this issue... I think (and hope) that you are convinced that supplied air is the way to go, but I wanted to provide the reason why filters are no longer permitted in the industry... because they were used (tragically unsuccessfully) for some time... J2 Here a few quotes from the web... “Respirators used to be replaced only when “break-through” was detected. Break-through is when the user can taste or smell chemicals while the respirator is being used. This detection method is not safe because it is impossible to know the exact point at which any chemical actually breaks through. Depending on each person’s level of sensory capabilities and fatigue, chemicals may be sensed at different times by different people. Also, some chemicals do not have a significant taste or smell, such as isocyanates.” “Di-isocyanates have low odor threshold and are not easily detected by smell. A dangerous level of di-isocyanates can break through a charcoal filter cartridge before the user is able to smell it. Painters using such paints must use an air-supplied respirator.”
