Clear coating
GPWT
01-19-2006 08:31:04
This question is not tractor related but concerns something that I have run into at work. We make a high priced product with a housing that is compression moulded of a black glass reinforced polyester. Places where the sprues are trimmed look light grey so we would like to try a coating that will make this look better, as close to a gloss black as we can get. I am thinking of using the clear coat part of a BC/CC system. Would this work, or would it react with the polyester thermoset? Any better, longer lasting alternatives?
Stan(PA)
01-25-2006 09:01:53
 Re: Clear coating in reply to GPWT, 01-19-2006 08:31:04
Localized heat normally restores the sheen to this type of material.
Frank Stalfire
01-19-2006 19:36:01
You can also go to peformancecoatings.dupont.com and send DuPont an email and they will contact you about your need and find you the correct product and contact
B-maniac
01-19-2006 13:52:08
Get a hold of your PPG jobber and have him get a hold of their lab,explain to them and they will be the best source for your answer.
