Paint problem need advice
Alias/Md.
01-23-2006 07:40:43
I have an antique Bolens Walk Behind two wheel garden tractor. I pulled the wheels and removed the tires and tubes. And, what I found inside was a lot of scaley rust which I sand blasted away. What I'm left with is a lot of pitted metal.
Now before I re-assemble the tires, I'd like to coat the inside of the rims with something that will fill up the pits. Thereby, making a smooth surface which will not cause the tubes to puncture.
My son advised me to use a silacone while my other son recommended I use an apoxy to coat over the inside of the rims. Now, my sons are good men but to the best of my knowledge, neither has actually dealt with this particular problem. So, if anyone here has had any experience along these lines, I'd appreciate your advice..... ..Thanks in advance.....gfp
Farmallgray
01-24-2006 14:17:26
 Re: Paint problem need advice in reply to Alias/Md., 01-23-2006 07:40:43
I would coat the tubes good with talcum powder
when putting them back in. That will help keep them from chafing.
Rod(NH)
01-23-2006 19:14:50
Hi,
You must have some unusual pits. I wouldn't expect typical pitting, after sandblasting, to have remaining edges sharp enough to puncture an inner tube. After I blasted the rims for my AC-B (which were pitted inside in some areas), I just applied two coats of epoxy primer to the interior. I didn't bother with topcoating on the inside as I could not see any benefit in doing so. I use tubes also and haven't had any problems. The epoxy primer provides an excellent protective surface in it's own right. If you are concerned about damage to the tube, you could knock down any obviously sharp edges with a small 80 grit sanding disc. You could also apply some polyester finishing putty, made by 3M and others, if you want to smooth the pitted areas. You would then sand and epoxy prime, as a minimum. Coating the area with either an epoxy resin or a liquid silicone as your sons have suggested would probably also help smooth things out but I've never done it so can't comment on how it works. I suspect there would be an adhesion problem with any priming or painting over silicone. I doubt that any type of smoothing effort is actually necessary, but I haven't seen the condition, so you'll have to be the judge. I'm just going on my own experience with filling pits for cosmetic reasons - it's a time-consuming pain to do, and I'd want to avoid it where I could.
third party image Rod
CNKS
01-23-2006 19:23:56
 Re: Paint problem need advice in reply to Rod(NH), 01-23-2006 19:14:50
Rod, you're right about the need for epoxy and no need for topcoat on the inside of the rims. However, I do the inside of the rims in the same operation as the outside, so I just paint everything. I have never seen sharp edges after sandblasting either.
B-maniac
01-23-2006 18:14:28
As long as you are using tubes the pits wont ever bother,do like CNKS said. Some are tubless and will leak if pits aren't filled in.
CNKS
01-23-2006 16:42:02
I don't know that the pits are any different than those inside the tractor rims that I have done. If they are smooth, just coat with epoxy primer and paint with the same paint you use on the outside. Unless they are very rough, the rough edges should disappear by using a wire brush on an electric drill.
