What kind of paint booth do you have
Gettin' Old
01-23-2006 17:42:29
looking to clean up my paint jobs ,too many specks of dirt or dust particals.
B-maniac
01-23-2006 18:32:55
 Re: What kind of paint booth do you have in reply to Gettin' Old, 01-23-2006 17:42:29
You just need a clean room ( not your workshop) wet the floor. Use a small fan that moves the minimum of air flow. Air carries contaminants,the less air you have to move across your wet paint the better until it sets up. The best advice is to paint it in parts and not as a whole. You can control everything better,and use less air movement because of less fog. Yes it takes longer but you cant put a clock on quality.What few specks you still may get ,you can spot sand with 1500 grit and hand rub to perfection.I have yet to see the "perfect" "as sprayed" paint job.
