Some prep paint tips wanted
Randy_NE
01-30-2006 07:56:40
My 43 H is parked outside waiting for me to protect her.
I am in the process of removing parts to be sandblasted and primed, she is a good runner so I think I will not do any engine work.
My questions are do I use a high temp paint for the engine? If I paint the small parts with a rattle can using 2150, do you paint the bolts etc. also or wait till you put the pieces back on?
Randy
Green Thumb
01-31-2006 18:53:14
 Re: Some prep paint tips wanted in reply to Randy_NE, 01-30-2006 07:56:40
When i do a tractor i dissassemble it complety and hang the parts on a clothes line, and paint them along with the tractor. Then put it all back together, sand the sheet metal, and the big open spots with 300 grit sand paper, and then give it a second coat. This way you dont have to do any brush touch up. Takes a lot of time, but the more you invest the more you get out.
PW Repair and Restorations.
CNKS
01-30-2006 16:54:26
Same paint on the engine as the rest of the tractor, unless you want high temp paint on the manifold. You can paint the small parts with a rattle can if you want, a spot gun will do a better job. Paint the bolts first, then touch up with a brush after installation.
