paint removel
terry fugate
02-09-2006 14:11:48
some were on one of these sites some time a go was some info one paint removel by useing a batter charger and water . what did they put in the water; I cant seem to find the site, thank .
terry fugate
02-10-2006 11:30:59
 Re: paint removel in reply to terry fugate, 02-09-2006 14:11:48
got it thank's for your reply ""
Paul L
02-10-2006 09:38:49
Hey,
I was reading somewhere else on this site that a guy removes rust off the whole tractor using electolysis and a pressure washer. Does anyone know how this can be done? Thanks. Paul
DiggerLarry
02-10-2006 07:28:34
You put washing soda (Arm and Hammer) in the water. Check out Frank's site. He's the expert.
REDJD
02-09-2006 21:23:20
The battery charger removes the rust.Lye is used in the water as a conducter, hooking the ground side to the part to be derusted and the positive side to a scrap piece of metal transfers the rust to the scrap metal.The two pieces cannot touch in the water.The lye also helps remove the paint.
If the piece you are derusting is very large you will have to turn the battery charger down to 6 volts.
Broomstacker
02-09-2006 16:44:10
Frank Boeger's website has info on electrolysis and also on lye gravy. Try www.fboerger.com
