2150 and hardener
Connals
02-20-2006 18:25:47
I have read many of the posts here. This is my first time posting myself. I have painted many tractors over the past 15 years and just recently started painting for customers. I tried using hardener in the last 3 tractors I have finished. I have always had great finishes with the 2150 red, desert sunset, and power orange; but with hardener it does not want to flow out to a glass-like surface. Tried more reducer, different air pressures... Anyone else had this problem?
tommyw-5088
02-21-2006 17:28:14
 Re: 2150 and hardener in reply to Connals, 02-20-2006 18:25:47
sounds like you need a slower reducer or hardner .if you get acrylic enamel hardner and reducer ,you can get slower products .hardner should allow more flow out and gloss. wear the right mask for the hardner .
Seth_ia
02-21-2006 09:27:08
Try using IH's hardener that they recently added to their paint line.
DEWAYNE UTRUP
02-21-2006 09:20:46
I have had similar problems till I used PPG's DXR 80 at the recommended 8:1 mix. This seems to work well for me.
Mike S 806/H
02-21-2006 06:32:38
What hardener are you using? I use acrlic enamel hardener with 2150, I also use acrylic enamel reducer,
TDK
02-20-2006 20:23:02
I use the 2150 with hardner and only had this problem except when mixed per the paint instructions(8:1). I use NAPA CrossFire 15117 Super Gloss hardner, don't know what you are using. I mix paint 4:1 and use 55 - 60 psi pressure with good results.
