2150 and clearcoat
rounder
03-01-2006 12:03:27
I am looking into using 2150 on my Cub, and was just wondering whether or not you can clearcoat it, and if so what kind is recomended? Thanks
tommyw -5088
03-03-2006 17:26:47
 Re: 2150 and clearcoat in reply to rounder, 03-01-2006 12:03:27
i have cleared ppg alk 200,case ih paint and jd paint .use hardner in the paint let it tack off then clear .i cleared the sheetmetal on my 5088 2 years ago .it worked fine
CNKS
03-04-2006 19:58:06
 Re: 2150 and clearcoat in reply to tommyw -5088 , 03-03-2006 17:26:47
What did you use for clear?
tommyw-5088
03-07-2006 05:35:43
 Re: 2150 and clearcoat in reply to CNKS, 03-04-2006 19:58:06
i used ppg automotive polyurethane clear might have been # 2001 ,but have also used 2042 speed clear ,and urethane clear .i basically used what my boss at the body shop gave me. our district ppg rep said to put it on wet-on- wet. spray the enamel (your base coat) ,with hardenr .let it tack off good then clear.i did the 5088 when it was 100+ degrees in the shop and i think that helped my sucess .i dont try to use clear when it is not real warm and dry .it can get blushed if it is humid.i have about quit doing tractors for coustomers ,i wont experment on a paying job. but i have enough equipment that i can experment .i also did my 504 with clear.and a track plow .somthing else i really like is ppg polyurethane industrial enamel. #300 .it is good for equipment and not too high $ .
Mike S 806/H
03-04-2006 22:17:11
I think he must of used alk-200 clear?? I looked up alk-200 didnt find out much but there was a alk-201 polyurethane enhancer to add to alk-200
CNKS
03-07-2006 18:10:18
 Re: 2150 and clearcoat in reply to Mike S 806/H, 03-04-2006 22:17:11
See the link -- apparently 201 is a hardener, used in a 15(200):1(201). Alk is near the top of the page. 200 is an acrylic modified alkyd enamel, perhaps similar to IH 2150. PPG considers it an industrial paint.
Mike S 806/H
03-01-2006 20:51:02
I know of a few guys at the pulls that clear 2150 and JD green. I never done it and I dont know what kind of clear they used,
CNKS
03-01-2006 14:16:22
I suppose anything is possible, but I don't think it is recommended. Usually at the minimum you can clear single stage acrylic urethane, using iso containing hardener in both the color and clear coats. There are also "inexpensive" base coat clear coat systems. Someone who has actually clear coated alkyd enamel may wish to comment, but from what little I know, the answer is no.
