small paint gun
david ahluwalia
03-02-2006 18:34:59
can anybody rec. a gun ?Iam restoring a old cub Cadet.I,d like to have a small gun I can mixup small batches to do sections and brackets at a time,.Somthing controlable easy to clean and user freindly because this is the only part of the project I know nothing about.
Richard Scott
03-06-2006 17:47:39
 Re: small paint gun in reply to david ahluwalia, 03-02-2006 18:34:59
Check this out: >Link
It>Link uses 35mm film cans for the paint reservior. There is a small plastic drop tube that you slip thru a hole you punch in the lid of the film can. Air blowing across the top siphons out the paint. Does a pretty good job. Clean up in a couple minutes, replace the film can with a new one (get at your quick film processing places) and clean or replace the tube. For $20, it's hard to beat.
rustyj14
03-03-2006 13:20:44
Go buy a paint gun called a "Touch-up" spray gun, and a small portable compressor! It will hold about 6 ounces, or so, and it sprays gently, so you won't get into trouble. they are available at most Auto paint/welding supply stores-not expensive! and, you'll need an air hose, too, along with a quart or gallon of laquer thinner to clean out the paint in it when you're done painting! Before applying the paint, clean the surface with mineral spirits, also available at the paint store, or the local hardware store!
