CN, I've never tried mixing the last coat of color with clear. I know that was done years ago and is indicated in the MTK tech sheet also, but I can't advise since I've never done it that way - with any paint. The way I've cleared MTK is just like another color coat but applied the following day instead of the normal flash time. You have up to 7 days to apply the clear but I like to get it on as soon as is reasonable. I wouldn't expect mixing clear in the last color coat would lighten the color since that has been common practice for many years and I've never read anything about it doing that. However, I really don't know. I have also never done any sanding prior to clearing so I don't know how any sandscratches would appear through clear - with any grit. I know that real basecoat is not sanded before clearing. If it is sanded, the recommendation that I've seen is to reapply more basecoat and then clear. If I were just going to sand the final color to remove dust nibs, etc, I'd use something like 600 grit, apply another coat of color and then clear - or, as you indicate, another coat of color mixed 1:1 with clear. My tendency would be the first, only because I've done it that way and know it works. I am unsure if the Scotch-Brite (I use the maroon, general purpose) will do the job with dust nibs - I've never tried it for that. You will get no gloss after 1000-1500 grit. You will need to compound to bring back any gloss. I use the MC161. When I first looked into the OMNI clears, I asked about the MC160 at my jobber. He didn't carry that particular product at all. So I went with the MC161. I have been pleased with it. It sets up faster than the MTK. I did have a small orange peel problem the last time I used it. I may consider using a slower hardener (MH169 instead of MH168) and some of the MR189 retarder next time. Don't mix up more than you can use right away. They say a 3 hr pot life and they really mean it. The stuff dries to the touch in not much more than an hour (about 75deg). Several hours later, any leftovers will be jello. I wouldn't bother with the 260. That's more for shops that do spot repairs and want the fastest possible turnaround. I'd stick with 161 for everything. I wouldn't expect a lot of increase in gloss by clearing. There should be some, but it probably won't be as dramatic as you might want. It isn't for me, using 3 separate coats of clear. Plus you always run the risk of making things worse, as I did in that fender photo-essay that's on my website. It's not that bad, but it's definitely not as good as it was just before clearing. The clear is nice over decals though, especially the cut vinyl ones - at least I think so. Of course that wouldn't apply for mixing clear with the final color coat. I suggest you try it on something scrap just to get an idea and evaluate any benefit for yourself. In all probablity, I think you'll decide to just sand the dust nibs with 400 or 600 grit, apply another coat of plain MTK and if the gloss is good, leave it at that. Either way, you run a risk of getting dust in that final coat, whatever it is. The main reason I'm clearing parts on my B is that I did so on the hood for the main decals and want other parts to have the same appearance. If it wasn't for the decals, I don't think I'd bother with the extra cost, effort and risk with the separate clearing work. Not much help here - just my thoughts on your situation. Rod
