desert sunset paint code
1030 brian
03-10-2006 18:48:22
Hi I was wondering if anyone has a paint code for Case desert sunset? My auto paint supply cant find or cross the PPG number. Any help would be appriciated. Thanks!! Brian
Lincoln
03-11-2006 11:43:42
 Re: desert sunset paint code in reply to 1030 brian, 03-10-2006 18:48:22
Looks like Rod has you pretty well taken care of. He is the man when it comes to paint questions. I was able to get PPG Omni in desert sunset. 81357 is the correct code, however, from what I was told this is an obsolete number and no longer appears in the computer. Have your paint supplier call the PPG color match people and they will give him the mixing formula. I am very pleased with the results using PPG Omni.
Rod (NH)
03-10-2006 19:45:56
Hi Brian,
Are you looking for a PPG number or looking to cross a PPG number to some other manufacturer? If you are looking for a PPG number, I show 81537 in the PPG list that I have. I have no idea personally if it's the correct shade or not. If you want a Martin Senour (NAPA) or Sherwin Williams number you should be able to find either of those by searching on-line at their respective websites. I can link you to the correct site(s) if you want.
third party image Rod
1030 brian
03-11-2006 05:57:20
 Re: desert sunset paint code in reply to Rod (NH), 03-10-2006 19:45:56
Thnaks Rod, sorry I should have been more clear. The PPG number in their book didnt come up in the computer so they really couldnt cross it to anyone else. If I could get another mfg code maybe it will cross back to PPG. I'm using the omni line from PPG for the first time, I have always used either centari or dulux from Dupont, but I understand that centari is being phased out. and I want a good single stage acrylic enamel. thanks for the help Rod! Brian
Rod (NH)
03-11-2006 09:36:18
 Re: desert sunset paint code in reply to 1030 brian, 03-11-2006 05:57:20
Brian,
If you are using the PPG OMNI line (MAE for acrylic enamel), then you want MAE81537, which is what my PPG listing indicates for Case Desert Sunset.
If you want to use the brand NAPA usually carries (Martin Senour) you probably want 3726, called Desert Sand (also beige). Sherwin Williams is just a basic Martin Senour with a different label and number. For Sherwin Williams, you probably want 3605, also callled Desert Sand or Beige. If you poke around in either MS or SW websites, you'll find that both the 3726 and the 3605 cross from PPG 81537. That's a good sign.
I also have a DuPont listing of old tractor paint codes. That lists a C8089 as a Case Desert Sand and also crosses (per DuPont) to Martin Senour 3726. There is no reference in the DuPont list for a cross to any PPG number. If you use the MS and SW website's competitor cross references, you'll get crosses for DuPont C8089 as MS5325 (beige) and SW30813 (beige) - which are different than above. Not such a good sign. A cross from DuPont to MS but not back the other way, from MS to DuPont.
Furthermore, if you go to DuPont's website (registration and access authority required for color formula info), you'll find that C8089 is referred to as a 1980 Ford color called Pastel Chamois!
So - conflicting information, which is par for the course. In my limited experience with old Allis Chalmers colors, DuPont and MS have both been confusing and inconclusive regarding a reasonable match to original. I have found PPG to be quite good in that regard. I would treat any cross reference information you get from any source as questionable. If you are particular about color shade, you may have to purchase more than one product and spray test samples to verify the product is what you want. Or simply believe someone else and hope for the best.
This is the first I have heard about Centari going south. Are you sure? I have been able to get it in my area, at least as of about 3 years ago. I am not that surprised that it might be being phased out, at least at the level of many jobbers. Delstar, PPG's long time competitor to Centari (also an excellent acrylic enamel) has not been available in my area for at least 10 years now - not enough local market nowadays for a relatively high priced old technology (acrylic enamel). Both of these products have been quite expensive for what they are and are not used to any great extent in the auto-refinish industry, which has been taken over, almost completely, by bc/cc urethanes. What little market there is left for automotive acrylic enamels, apparently is being filled by the "economy" lines - OMNI in PPG and NASON in DuPont. If you are used to Centari, can get it in your area and are willing to pay a premium price for it, you'll like it better than the OMNI MAE, assuming you can get it in a color shade that you are satisfied with. Forget Dulux altogether. That was a great product at one time long ago but now is (or at least should be) in the dust bin of history.
Take all this as opinionated info as I have no personal knowledge of any Case colors. I am only looking at information that is, or has been, published by the above paint companies. Proceed at your own risk.
Rod
1030 brian
03-11-2006 20:09:31
 Re: desert sunset paint code in reply to Rod (NH), 03-11-2006 09:36:18
Thanks guys! Rod acording to our local auto body supply place they're phasing out the Centari with really nothing taking its place. I guess most mfg are going to urethanes and Base Clear coats? Is there much difference between omni and centari? I havent painted anything for about 8 or 9 years, (got married, bought and remodeled a house and a baby on the way) now I have a little time to do this stuff and, wow! have things changed in a few years. I just hope that this omni paint is pretty good. I'm restoring this and I want it to look good. I wouldn't use Dulux anymore either, I had good luck with it the few times I used it, basically I wanted a step up from implement paint that you get from your local tractor dealer. Rod you mentioned in your paint codes a desert sunset and a desert tan, the sunset was used on the older tractors until '69 and desert tan was used from then until case went to white and red. Is this correct according to your sources? Thanks for the help!! Brian
Rod (NH)
03-12-2006 08:55:01
 Re: desert sunset paint code in reply to 1030 brian, 03-11-2006 20:09:31
I haven't seen any reference at all to any Desert Tan. PPG indicates a Desert Sunset and no other name with Desert in it. MS, SW and DuPont indicate a Desert Sand (not Sunset) and also Beige listed against the same number. Check out the links I provided for MS and SW. If you poke around the MS site in the competitor's cross reference search engine, you'll find that the number crosses from PPG to MS even though the name changes from Desert Sunset to Desert Sand in the process. That's one reason why it's very important to actually test a sample to be sure of what you are getting - if you are particular with shade. Trying to match up a modern automotive paint to an original tractor color from 50 or more years ago can be iffy indeed. It's a lot more uncertain than getting a color code off a fairly recent automobile and having it mixed up at the paint store. The automotive paint market is in automobiles not tractors. There is little economic incentive for major paint companies to maintain formula references over many, many years with all kinds of changes in paint chemistry and environmental regulations for what is basically a nil demand. If you get close to where you think you should be, you're lucky. You might even be better off, color-wise, in getting your paint at a Case dealer. They might have better control when contracting with a major paint manufacturer to provide large quantities of a very specific, custom built color to be marketed under the Case label. If they have an acrylic-modified alkyd enamel as they apparently do have in the IH colors, it certainly would be better than plain alkyd implement paint. Debatably, it could be as good, or nearly as good, as the OMNI MAE acrylic enamel. I don't know, but that could be an option for you.
I suspect your local jobber is dropping the Centari line because of insufficient demand to justify maintaining the mixing tints for it. I have no idea how widespread such a thing might be. A similar situation with PPG's Delstar is quite widespread as best I can determine, although it is still being made and seems to be available more in the midwest than here in the east. Yes, just about all, if not all, auto manufacturers now use urethane base/clear systems - they have been for well over 10 years. And the auto refinish business has, by necessity, followed the OEMs. Single stage enamels are old history as far as auto OEMs are concerned. In my opinion (and some will disagree) PPGs OMNI line of paints represent a good value for the money. However, they are considered "economy" products that tend to be used more in the low-end auto refinish market. You will likely not find an OMNI product used in any body shop that does panel repairs to reasonably new cars or trucks, even the OMNI base/clear product. The color control is not as good as the more expensive lines. Where it might be fine for an overall paint job, it would not be satisfactory for a replacement fender that had to match the existing door next to it. OMNI can't compete with the higher-priced products for that part of the market. You usually don't get into such a situation with tractors so that is less of an issue. I think that you would find that Centari would not be as thin, would cover better with fewer coats and would apply easier in general. Not that OMNI is bad. It's that Centari, in my opinion, is better. But it's also more expensive. I haven't bought either recently so I don't have a current, accurate cost comparison. However, I would guess that Centari is about twice as expensive as OMNI MAE for an equivalent mix in the same color cost bracket, all components considered. Is Centari twice as good as OMNI MAE? If you are considering unhardened versions of both paints and put a high value on recoatability, the answer may be yes. If not, then I think the answer is no.
I don't want to start up the isocyanate debate here again but I am assuming you do not have a supplied air breathing system to safely use hardener additives and are considering unhardened enamels only. If that's not true, then your options are greatly increased, essentially limited only by how much you want to spend.
Rod
1030 brian
03-12-2006 17:59:09
 Re: desert sunset paint code in reply to Rod (NH), 03-12-2006 08:55:01
Rod, sorry I was refering to the Desert Sand color not Desert Tan. Thanks for all of your input with this. I am going to try and get some results from the supply place this week. These guys are pretty helpful, they said I could bring in a piece and they color match it. It should be real fun trying to locate a piece with 40 year old paint that will buff out enough to color match. Oh well we'll see what happens! Thanks again Rod for your input, you seem to be very knowledgable in the paint field.
Brian
